Flying Miata Willwood kit - Versione stampabile +- Mx5Italia (https://www.mx5italia.com/forum) +-- Forum: Vendo e compro (https://www.mx5italia.com/forum/forum-8.html) +--- Forum: Occasioni dal web (https://www.mx5italia.com/forum/forum-37.html) +--- Discussione: Flying Miata Willwood kit (/thread-17898.html) |
Flying Miata Willwood kit - sempre luky - 16-04-2012 Fletch Ha scritto:Se prendessi le pinze per i dischi piccoli e poi volessi passare agli 11", sarĂ possibile, in seguito, ordinare solo le staffe, visto che si tratta di una produzione limitata? Nel caso te le faccio io! Flying Miata Willwood kit - Fletch - 16-04-2012 :WohoW: Flying Miata Willwood kit - oldcafe - 16-04-2012 Posts: 202 This kit replaces all the components of your front brakes with the exception of the rotor. If you want to run a different size rotor than the ones on your car now, you'll just have to order the appropriate brake kit and the rotors to match. The factory brackets are not used. So you'll actually save a bit of cash if you were planning on a rotor size change. The lines are non-optional. Wilwood calipers use a different connection than Mazda ones do, so your stock or aftermarket lines won't hook up unless you already have Wilwoods. If you're running on track and having heat management issues with your fluid (not your pads), you might be better off with the (big) Big Brake Kit. If you're okay right now and just want lighter weight, the ability to easily change pads and more even pad pressure, this would be a good option. The standard pads are Wilwood BP-10s. We could probably substitute other Wilwood pads for no charge, although I need to confirm our cost on those. Flying Miata Willwood kit - .SharK - 16-04-2012 Per quei soldi, vi fate il kit corrado, montate dei 15 e frenate infinitamente meglio. IMHO servono solo a chi, come il Costa, vuole i 13" (o 14") ma buoni risultati di frenata Flying Miata Willwood kit - Fletch - 16-04-2012 Ma pinze Wilwood a 4 pompanti + dischi Corrado (48 dollari al paio) su cerchio da 15, no? Flying Miata Willwood kit - .SharK - 16-04-2012 non ha molto senso... con 100$ in piu' prendi ben altre cose: http://949racing.com/949-miata-big-brake-kit.aspx Flying Miata Willwood kit - Fletch - 16-04-2012 Uhm... ci rifletto. Flying Miata Willwood kit - Fletch - 17-04-2012 Alby, mi sa che hai ragione. Flying Miata Willwood kit - [Slide] - 17-04-2012 ma le pinze son le stesse no? si potrebbe, in caso, contattare quelli di 949 per un bg del big kit Flying Miata Willwood kit - Fletch - 17-04-2012 Shuy Ha scritto:ma le pinze son le stesse no?Pare di si. Shuy Ha scritto:si potrebbe, in caso, contattare quelli di 949 per un bg del big kitTentar non nuoce. |
