Group Buy : Zeromotive Vacuum Block (useful for IRTB setup) *REV9*
[Immagine: rev9_ad.gif]
Hey everyone,
We've had developed a Miata-specific Vacuum Block to help monitor IRTB setups correctly. It is made to monitor more accurately your vacuum with your MSPNP or with a gauge.
[Immagine: gb_image.jpg]
The Vacuum Block comes with dimples in the body where you need to drill holes for your fittings (3 minutes job). This item is used to give a better reading to aftermarket ECU (such as MS2V3). If you only tap one runner and run that to the ECU, you're only getting the vac air from one runner. If you run all four into a vac block first and then to the PNP you're getting an average from all four making tuning easier and more accurate.
[COLOR="Red"]MINIMUM REQUIREMENTS:
[/COLOR]
We only need 10 buyers to make it possible. It's a cheap item, so I hope we'll be able to make it!
[COLOR="red"]GROUP BUY DISCOUNT:
[/COLOR]
MSRP: $49.99
Discounted Price : [B]$39.99 [/B] SAVE 20%
AVAILABILITY:
The faster we obtain 10 buyers, the faster it can be processed.
HOW TO JOIN THE GROUP BUY ?
Visit the following link http://rev9autosport.com/zeromotive-vacuum-block.html, add the product to your cart and send the payment.
PAYMENT:
The payment is 100% refundable if we don't meet the minimum requirement.
DURATION:
Group buy will end on April 15th 2012.
Maxime L. | REV9 Autosport
Hey! Thank you for the group buy!
How much for shipping to Italy?
And how much for shipping to a APO/AE box?
Thank you!
Fabio
Hello Fabio,
Shipping to Italy would be ~$19 in total (brings the price to ~$59).
Thanks!
REV9 Autosport Ha scritto:Hello Fabio,
Thanks!
Ok, and Can you ship to an APO/AE box? The price should be the same as a normal shipping to USA if the piece is not too big and heavy
Thanks!
Hello,
I guess there wouldn't be any problem. If the address is in USA it should be fine.
Thanks!
Messaggio errato da cancellare.. sorry
non ho capito a cosa serve questo vacuum bloc... :oops:
anche io :chessygrin:
Da quel che ho capito serve quando monto una ECU diversa dall'originale.. ma a cosa serva di preciso boh..
Serve solo per chi ha i corpi farfallati, si convoglia la pressione dei 4 condotti in questo scatolotto che ne restituisce uno solo in modo da farla leggere correttamente alla centralina od un vacuometro
  [Vari] Group buy (?) GAZ Gold Pro Number34 0 3,527 24-01-2020, 16:50
  [RC] Group buy per smarttop zef 28 31,181 06-03-2018, 16:58
  Group Buy Pomello Cambio "JGTC Style" by Techno Toy Tuning Pez 5 7,823 21-01-2018, 02:41
  [NA NB NC ND] Nuovo Group Buy Cerchi 6UL ilGerry 50 39,415 16-11-2017, 20:12
  Group buy cerchi Evo corse GreyShark 5 6,728 14-11-2017, 11:03
  Group buy Japan Racing Marco Ferrari 21 18,240 30-04-2017, 12:40
  Group Buy Pastiglie Project Mu Pez 4 6,041 05-04-2017, 11:24
  Group Buy cerchi 6UL Gagio 261 116,491 24-02-2017, 12:33
  [ND e non] group buy JBR induction hose/altro v3rsus 43 32,978 10-11-2016, 11:38
  Group buy per minigonne feed style !!! Giamma_jdm 13 12,929 27-07-2016, 14:52
