Saro' presto miatista!
E' il diametro dove avvita il bullone che tiene la puleggia ad essere sottodimensionato per la coppia esercitata giusto?
Pero vedo appunto che la puleggia dello short nose ha 4 asole mentre quella del long ne ha 8, quindi direi che lascia poco spazio a dubbi su che albero abbia
In ogni caso leggo di una percentuale bassa di rotture, basta tener d'occhio il bullone periodicamente.
Tranquillizzatemi voi :oops:
@ Miata.Shark, fatto
Wink la percentuale è davvero bassa quindi stai tranquillo... solo assicurati di fare questa operazione quando rifarai la distribuzione:
REGULAR REPLACEMENT OF THE BOLT RECOMMENDED
The failure starts at the BOLT. It is undertorqued, overtorqued (stretching and yielding it), or the bolt creeps (stretches or fatigues) over time loosening the connection. An overtorqued bolt can not only stretch but cause the crankshaft threaded end inside diameter to expand. So even a fresh bolt may not retain it's torque. In any case as the bolt loosens the key, keyway, and timing cog take a beating. Only the crankshaft shoulder and timing cog can take the loads of operation. When the bolt becomes loose, the load shifts from the crankshaft shoulder to the other parts which rapidly self destruct.
Yes, most of the fault lies with the weak design that asks too much of that bolt. For this reason, the solution is NOT to leave the bolt untouched. That bolt is becoming older and older everyday. Every time you start the engine, the risk for failure increases. The bolt should be on a regular replacement schedule. I would recommend annually.
The bolt can be removed and inspected, the key can be slid out (sometimes) and examined without any other disassembly of the engine. I have a special socket I shortened with a grinder so I can remove the pulley bolt without removing the front anti-roll bar. If you ever find the bolt has not retained its torque, ferrous powder on the bolt or key, or the key rusted or smooshed, these are signs that the system is starting to fail. Sometimes a wobble can be seen when the engine is running. A wasted crankshaft keyway may, however, still rotate without runout. The static tension in the timing belt and accessory belts usually prevents a human hand from wobbling the lower pulley with the engine off. The only way to get a read on the crankshaft condition is to take the system apart.
If everything is in order, clean up the crankshaft and bolt shoulder seating surface with brake cleaning spray. Toothbrush the inside of the crankshaft threaded hole. Apply Loctite thread locker or sleeve retainer to a new bolt. Install NEW bolt and key. Torque to 87 foot pounds.
THERE IS A LOCTITE REPAIR
Recognizing that many people can't afford to replace their engine or crankshaft, I will mention that there are successful repairs involving shims, new keys, welding and the like. Probably the best repair is a Loctite fix that has been developed with the direct assistance of Loctite engineers.
senti dmax che è lì in zona tua se ti sappia consigliare un buon meccanico
La distribuzione e' gia stata rifatta dal vecchio proprietario. domani passo in mazda e chiedo il ricambio del bullone.
senza servosterzo deve essere di importazione, per curiosità se ha il libretto originale, guarda da dove.
un mio amico ne aveva una bianca senza servo e vetri elettrici ed era francese
Probabilmente hai ragione perche non ha la targa pre 94', domani controllo ora non ho il libretto sotto mano.
Phreno Ha scritto:Probabilmente hai ragione perche non ha la targa pre 94', domani controllo ora non ho il libretto sotto mano.
è solo una mia curiosità Mrgreen
e complimenti per l'acquisto
visto quanto è utile questo moderatore :chessygrin: ?
la percentuale è bassa ma è meglio prevenire che curare
mercatino pezzi vari
Macchina ritirata!
Che dire... 150km percorsi e avevo il sorriso stampato per tutto il viaggio.
Non saprei che impressioni dare cosi a caldo. so solo che mi sono veramente divertito!
Eccola qua!
[Immagine: dscf2023.jpg]
[Immagine: dscf2025.jpg]
[Immagine: dscf2021z.jpg]
[Immagine: dscf2022.jpg]
  Futuro miatista(forse) Ajeje 9 7,044 12-05-2016, 19:19
  La biblioteca del miatista Gio Slashbait 2 2,741 23-10-2013, 00:38
  Miatista su Evo agosto Brunix 32 13,544 13-09-2012, 16:26
  Supporto Miatista Esperto! theblindbard 16 7,615 30-08-2012, 15:18
  Cercasi miatista varesotto Drakkar 23 9,127 07-02-2012, 12:30
  Ma quale miatista key!!!!!!!!!!!! kawa62 6 4,908 24-07-2011, 11:38
  Vita da miatista... Flex 1 2,445 25-05-2011, 20:08
  Wanted Miatista con T-shit sushi al raduno del Garda WillyWilly 5 5,711 14-05-2011, 18:34
  Cronaca di un acquisto lampo... MIATISTA!!!! Lordjulian 45 19,525 28-06-2010, 09:32
  La rinascita di un Miatista..Speranza e voglia di riGuidare! DreaMerX*5 15 7,263 27-01-2010, 18:44
