info NC.
che cerchi sono quelli che monta la nc CUP in tutte le foto?
quelli bianchi col canale lucido. si posso acquistare , se si, a quanto?
metti una foto per favore
Claudio- 91' Silvia S13
ex NBFL bigusto driftosa
Non ho presente quali siano.....
Porsche Boxster
Le mie EX -
Click to view
NA 1.6 90cv
NA 1.8 130cv
NC 2.0 3rd Generation Limited
[Immagine: img_mazdaspd_motorsports_news105_playboy.jpg]
sono quelle di serie da regolamento
[Immagine: 01_mx5_rfr09_opta.jpg]
The use of a MAZDASPEED intake (0000-06-5150-KT) and a MAZDASPEED high-flow exhaust (0000-06-5450-KT) is required and pushes power from 170 to the 200 hp range. All MX-5 Cup vehicles are equipped with a six-speed manual transmission and may be run with the optionally available limited-slip rear differential.
The MAZDASPEED Motorsports Development MX-5 Cup suspension kit is sole approved suspension enhancement of 2006-spec race cars. The kit consists of coilover shocks with 5-way dampening adjustment, spec springs and stock height bumpstops as well as anti-roll bars.
The braking system has its own specs for rotor size but modifications can be made to backing plates and dust shields while pads, fluid and lines can be replaced, the latter can be upgraded to racing spec stainless steel or Teflon.
Wheels are limited to two 17 x 7 OE offerings, each weighing and costing the same. The series spec tire is Hankook’s DOT-approved 225/45-17 Ventus Z214, which sports a C50 compound. The wet spec tire is the Ventus R-S2 Z212.
Il sovrasterzo è quando si spaventa il passeggero, il sottosterzo è quando si spaventa il pilota
Griflet Ha scritto:The use of a MAZDASPEED intake (0000-06-5150-KT) and a MAZDASPEED high-flow exhaust (0000-06-5450-KT) is required and pushes power from 170 to the 200 hp range.
Massimiliano
'02 1.6
Tein SS + FM sway bars
MiataMania
Questi?
[Immagine: 424350287_eb1baa9498.jpg%3Fv%3D0&usg=AFQ...rXHyoKgxTQ]
ho preso le specifiche dal sito mazda USA
il regolamento e le foto delle gare sono su http://www.mx-5cup.com/
le modifiche ammesse sono qui http://www.mx-5cup.com/series.php?page=MX5carfacts dove appunto dice che le ruote sono OEM 17x7 e che pesano tutte uguali
evidentemente la foto a laguna seca è più da show che riguardante una delle auto iscritte, e poi era il mio sfondo preferito del 1000 miata Thumbup
lucios Ha scritto:Questi?
[ Immagine ]
esatto lucio, proprio questi.
nessuno ha info quali costo,reperibilità,marca etc etc di questi cerchietti?
grazie.
  [ND] Info urgente su garanzia!!!! Roberto_mx5_rf 35 10,642 05-08-2023, 00:22
  [NB FL] Info colori interni randomuser2344 7 3,117 24-05-2022, 15:25
  [NB FL] info su auto straniera (ma europea) limner 6 4,575 04-01-2020, 17:20
  Info nb 1.8 Uomonero 1 1,887 22-10-2019, 19:24
  Info NC 2.0 in vendita su Autoscout Zamp_Mx5 5 4,518 28-03-2019, 13:16
  Info per un NeoMiatista sandroEGO 6 5,911 01-10-2017, 23:48
  Info su Nb 1.8 marvel 4 3,311 11-08-2017, 15:35
  Info su mx5 nbfl 1.8 2004 svizzera anomalie aiutooo FABIOSLK 12 5,089 20-10-2015, 06:45
  info su acquisto mx5parts Marti 2 2,735 20-08-2015, 09:58
  Info prezzi NC anniversary Kim 2 2,730 21-07-2014, 14:31
