Fari Stealth Jass Performance
http://www.jassperformance.com/shop/mazd...Headlights
[Immagine: red1-600x600.jpg]
[Immagine: fit-600x600.jpg]
[Immagine: 20170423_143826-600x600.JPG]
[Immagine: IMG_4033-600x600.JPG]
Stealth (Flush) MK1 Headlights
The Jass Performance Flush Headlights were initiated as performance mod, aimed to reduce weight and optimise air route and temperatures. Best at this, they were later design and function optimised and developed further towards the following requirements.
-Tempting, integrated design
- Optimal light output
-Perfect fit and minimal (less than OEM) tolerances
- Straight, fully reversible fit, without modifications
-Lightweight
-Long lasting finish (scratch, UV resistant)
-Fully (literealy) adjustable option, as nearly all of those cars, have seen accidents, leading to smaller or larger tolerance differences
-Reuse of OEM bonnet support rod
-Washer expansion tank relocation kit
-Fuel charcoal canister relocation kit
-Optional Cold Engine Side Air Intake kit (to follow in short as a add on)
-Happy to confirm the featured end products ticks all checkboxes and the design speaks for itself.
The installation is intuitive and doesnt take long, supported by a provided manual. Everything needed is provided with the kit.
The used headlight units are the ones we use in the Jass Performance Low Profile light, as their very good light output has been constatly confirmed over the years. Should you already have the Low Pros, an option for the Flushed Headlights without the headlight units is provided.
Photos of the estimated tight fit are available in the image gallery. As the development and testing took few good years, their design could get direct confirmation at few shows and their function in real life or track use, as seen in the gallery.
A dumà
Sono un amante dei fari flush e uno dei tre più grandi detrattori al mondo dei pop up ma devo ammettere che col risultato finale proprio non ci siamo.
Terrificanti.
Inviato dal mio SM-J500FN utilizzando Tapatalk
Fletch Ha scritto:Sono un amante dei fari flush e uno dei tre più grandi detrattori al mondo dei pop up
pagherai per questo : Evil :
Mexo Cinqo Ha scritto:http://www.jassperformance.com/shop/mazd...Headlights
-Lightweight
Hai una % sulle vendite?? 😜 😜
- GAZ - REMUS + terminali "ad hoc" - 225/45 R17 su Rota Grid 17x9 ET42 Chameleon - K&N - Barre anti-rollio RACING BEAT - Tubi Freno Treccia
In cerca di
- Collettori scat - Varie ed eventuali
Magari XD
Questi però costano circa la metà dei Jet Stream
A dumà
Sì ma valgono un ventesimo come resa estetica.
A me rimbalzano sia gli uni che gli altri.
questi però hanno il vantaggio che quando ti rendi conto di aver fatto la minchiata rimetti gli originali ed hai salvato il muso
servono anche ad illuminare la strada o sono solo un mero orpello estetico?
su mx5italia dal 2009
la mia 1991 NA 1.6 v-special
  [ND] Fari di che tipo Roberto_mx5_rf 9 4,279 26-06-2024, 00:24
  [NC] Fari anteriori con macchia di condensa Mister X 14 9,189 20-08-2021, 09:09
  [NB FL] Fari NBFL delavega 8 6,080 09-02-2021, 10:14
  [NA] tremolio fari anteriori andrewosky 17 12,143 23-07-2020, 14:19
  [NB FL] Fari ballerini Robbie 2 3,507 16-06-2020, 16:36
  [NA] Plastiche cofano/fari Woody 4 5,518 10-04-2020, 08:40
  [NA/NB]  Montaggio hard top bracket Jass Alessandro 9 9,378 03-12-2019, 13:53
  ND 184 cv - Regolazione Fari Anteriori willy 11 11,777 07-11-2019, 23:21
  Ripristino colorazione fari originali _GiuSal_ 3 4,193 13-07-2019, 12:03
  [NC FL] Foto paraurti posteriore NC2 con fari NC1 LotusGiorgio 2 5,118 28-08-2018, 16:16
