consiglio tecnico
Cioa a tutti, sono qui per chiedervi un consiglio.
Ho già montato da diverso tempo gli oggetti sotto linkati
http://www.ilmotorsport.de/shop/article ... a3fc1e17ef
con risultati soddisfacenti
vi ricordo che ho sotto i koni sprt regolabili.
Bene secondo voi montando questo
Che benefici si possono aspettare?
MX-5 CALABRIA
Aspetto vostri utilissimi consigli. Grazie
MX-5 CALABRIA
Racing Beat:
http://www.racingbeat.com/FRmiata.htm
Suspension Package
01-05
Part Number: SuspensionPackage01-05
Retail Price: $387.90
Qty:
Suspension Package for 2001-05 Miatas (except Mazdaspeed versions)
Here’s you chance to transform your Miata into a slalom-slicing screamer! One of the first steps that can be taken to improve the handling characteristics of a 2001-05 Miata is the addition of a larger front sway bar and a set of performance lowering springs.
Racing Beat has incorporated 30 years of racing experience in the design of our suspension products. All of our suspension components are designed by Racing Beat exclusively for the Miata and will improve the handling of your car dramatically.
It has been long recognized that a good set of performance tires will have the biggest impact on a car’s handling. The next step to improve the handling of your car is to reduce body roll through the use of performance sway bars and suspension springs. Body roll occurs when one side of the suspension is compressed (referred to as “jounce”) while the other side extends (referred to as “rebound”). The use of larger diameter sway bars limits the body-roll of a car by making it harder for the driver-side and passenger-side suspensions to move in opposite directions.
Another method used to achieve less body roll is through the use of stiffer suspension springs. A stiffer spring will compress less than the stock spring when subjected to the equal amount of cornering force. Less compression on the outside edge of the car results in less body roll. (To fully optimize the performance capabilities of these springs, we suggest that you consider replacing your stock shocks with a set of performance shocks.)
The Racing Beat Suspension Package includes:
Street Springs – Front (Part Number 54018) Net Price $44.00ea
Street Springs – Rear (Part Number 54022) Net Price $44.00ea
Front Sway Bar (Part Number 54106) Net Price $170.00
Sway Bar Brace Kit (Part Number 54120) Net Price $85.00
Regular Price for the above package- $431.00
Special Package Price - $387.90
(Save $43.10)
Included Components & Specifications
1. Racing Beat Street Springs:
Increase Over Stock 28% front, 23% rear. These linear rate springs have been designed to lower the Miata approximately 1-inch front and rear.
2. Sway Bar Brace Kit (select for details)
3. Tubular Front Sway Bar (select for details)
Recommended Optional Components:
Sway Bar End Links
(Listed below in our order of preference)
1) The original stock sway bar end links may be used, but they are not recommended.
See Lower Control Arm Reinforcement Flanges for important information.
2) Our Heavy Duty End Links-1999-05 Front can be used in place of the stock end links, but we strongly recommend the addition of the Lower Control Arm Reinforcement Flanges.
3) *Racing Beat's Recommended Option*
Use of the Heavy Duty End Links AND the Lower Control Arm Reinforcement Flanges.
If you have any questions regarding the products listed above, or would like help in determining the optimum suspension upgrades for your Miata, contact us at (714) 779-8677.
MARVEL
MX5 NB by Finelli Racing & Flyin'Miata parts
Maruha IRTB kit in work
Grazie Marvel, come sempre gentilissimo.
Altre opinioni o esperienze?
MX-5 CALABRIA
nofear Ha scritto:Cioa a tutti, sono qui per chiedervi un consiglio.
ma con i koni sport e le barre ci passi sui dossi o li eviti per non rimanere incagliato?
Io prego ogni volta che passo anche solo un avvallamento, se montassi delle barre di irrigidimento toccherei l'asfalto pure da fermo! :roll:
MX-5 NB 1.8i 140cv Chaste white del 1998
Differenziale autobloccante Torsen
Assetto regolabile Koni sport (giallo)
Scarico Remus
Volante momo 340mm
  [NC] Consiglio assetto uso trackday falcon89 19 4,901 23-12-2025, 13:19
  [NB] Consiglio JR29 e bulloni ruota. Erikun 7 3,847 11-02-2025, 18:11
  [NA] Consiglio dimensione JR3 Acyber 6 3,436 03-02-2025, 15:33
Information [ND] Consiglio Pneumatici Invernali SauroHD 11 4,964 22-11-2024, 12:00
  [ND] Consiglio nuovi ammortizzatori Abe77 5 4,789 28-03-2023, 21:10
  [NA] Consiglio per sostituzione ammortizzatori Mazda MX 5 NA del 1991 Gianni54 7 9,000 10-12-2022, 16:04
  [Vari] Consiglio su manometro pressione Sereno 6 4,779 28-12-2021, 20:37
  [NB FL] Consiglio su miglior coilover sotto i 1000€ AleReda98 16 12,909 19-03-2021, 17:35
  [NC/RC] Consiglio regolazione coilover dnr33 11 9,728 16-07-2020, 11:26
  [NC] Consiglio gomme Lele76 1 3,608 07-06-2020, 10:44
