Coilover Raceland
ale.sg Ha scritto:Credo che la componentistica faccia la differenza più che i numeri
Un modo molto semplice di dire "compra i vmaxx dal mio catalogo, (sono la stessa cosa) ma ci margino io piuttosto che un altro commerciante".
Credete che facciano dei vmaxx per miata specifici per flyn miata??? Ma allora crediamo anche agli asini che volano e che paperina abbia le tette..
Siate affamati, siate folli!
7even Ha scritto:Un modo molto semplice di dire "compra i vmaxx dal mio catalogo, (sono la stessa cosa) ma ci margino io piuttosto che un altro commerciante".
http://clubroadster.net/vb_forum/showthread.php?t=30107
L
i ne parlano e risponde keith tanner.
Interessante il primo intervento:
Citazione:I've never seen a set of Racelands, but based on the pictures I can see a few differences that indicate they're not the same shock. The size of the lower bushing, for example. The bumpstops are different (although I'm not sure what the production version of our stops will look like) and based on the design of the wrenches that come with the Racelands, I suspect there's a difference in the perch diameter. There are some similarities in design, many of which probably come from the fact that they're both solutions to the same problem. Someone send me a set of Racelands or even some good pictures of them, I'll confirm.
The standard V-Maxx spring rates are 70 kg/cm front and 60 kg/mm rear. It's no secret, it's printed right on the spring and the TuV paperwork. I suspect most people just don't recognize "140-70" as being a metric length and rate. We dropped the rear rate to 46 kg/cm. I can assure everyone that we are not using the same rates as were used in Europe. V-Maxx couldn't understand why we'd change them (most of their customers seem to be more concerned with the amount of drop) and they're winding custom springs for us.
For those who didn't see it in the initial announcement, the FM rates are 20 kg/cm for the secondary springs (front and rear), 70 for the front and 46 for the main primary. That's 112 lb/in, 391 lb/in and 258 lb/in for rates.
I don't have a full dyno graph, but I do have a couple of points for high- and low-speed damping.
For assembly, the rears can be quickly assembled without a compressor. I would recommend a compressor for the front, but they don't need much. That's for the NA, I don't recall needing a compressor for the NB but Brandon's the one who installed those in the front.
We didn't concentrate on the potential slammitude of these coilovers when developing them. We were looking at ride quality, ability to put down power and handling at our usual ride heights. I can tell you that the 11" front ride height I saw was with the secondary springs in place. Once we've got the shorter production springs in hand, I might see how far I can drop one of these simply for fun. No guarantees on how they'll work as a suspension at that height, of course!
Di sicuro hanno cambiato le molle
Credo che FM faccia margine su tante cose, ma basi il suo successo commerciale più sulla capacità di fornire componenti adatte alla miata che su marketing spregiudicato.
Poi a cambiare SR e valvole in fase di montaggio ad una azienda, specialmente se su numeri medio grandi di certo non costa un granchè.
Ah e cambiano pure i bumpstop.
NA 1.8 '94 elan style
Lorenzo
La mia frase era detta in generale e non riferita al caso specifico dei vmaxx, su cui so poco.
NA 1.6 Montego Blue
..:chessygrin:..
oggi ho montato gli anteriori, domani mattina finisco
li ho messi oggi.
sta sera provo, per ora ho messo a 52cm ant e 53 post (dal bordo inferiore del cerchio al passaruota)
ho dovuto limare un filo la parte inferiore degli ammo perchè questi sono larghi 46 e si incriccano mentre i Tein un micron meno di 45 ed entrano perfetti
ma le antirollio posteriori le hanno fatte con il fil di ferro? sono sottilissime :haha:
pazzesco quanto si possa scendere con sti barbonland!!
Mi è sfuggito qualcosa, hai tolto i Tein ed hai messo i RL?
oldcafe Ha scritto:Mi è sfuggito qualcosa, hai tolto i Tein ed hai messo i RL?
sacrilegio!
ale.cigo Ha scritto:li ho messi oggi.
:blink_:
NBFL Starry Blue bye bye
Benvenuta ND Artic White!
  [NB FL] coilover Tecna gradient 4 1,794 12-11-2025, 21:33
  [NC/NC FL] Rebuild Coilover BC: idea (malsana?) e pareri Bulz 1 1,204 04-08-2025, 13:40
Wink [NA/NB]  Help identificazione coilover! dotsynergy 0 1,188 16-09-2024, 20:16
  [ND] Coilover ST Supension, Meister R o BC Racing?? dnr33 11 7,355 19-10-2023, 21:00
  [ND] meister r coilover alex 62 11 7,791 12-04-2022, 17:56
  [NC] Coilover BC racing Pes mx5 3 3,807 19-04-2021, 09:07
  [NB FL] Consiglio su miglior coilover sotto i 1000€ AleReda98 16 13,108 19-03-2021, 17:35
  [NC/RC] Consiglio regolazione coilover dnr33 11 9,874 16-07-2020, 11:26
  [NC/RC] Regolazione altezza coilover GabarZZ 21 18,218 10-03-2020, 17:43
  [NB] Coilover HSD? Miatafan 21 19,668 26-10-2019, 16:50
