Gagio Ha scritto:E quindi risparmi perche' ne puoi comprare solo 2???
Dipende quanto costa ogni razza.
Era un mero discorso di armonia delle forme.
su clubroadster si trova questo
http://www.clubroadster.net/vb_forum/sho...hp?t=25080
Citazione:How to fit 15x8+0 wheels
by scooby steve33
So the amount of people i see asking the same question over and over and over and over made me think it would benefit everyone if we just made a 15x8 0 offset thread. I had some on an NA so ill put in my two cent if other people have info on NBs and so on go for it.
WHEELS:
15x8 0et
TIRES:
you can run a
165 45 -15 really really low profile and stretch, looks like shit
195 45-15 some stretch, looks decent can go low with some camber
195 50 -15 a more substantial looking tires (taller sidewall) may be a tad bit harder to fit
205 and larger going to be tough to fit but can be done
Camber:
First off you dot have to "buy" camber. Your stock arm do all the adjusting one should need for these. Use the eccentrics on the control arms to increase or decrease camber. Then GET AN ALIGMENT! not one to match OEM specs but to make sure its not completely destroyed. Match the camber from side to side. check your toe, personally i try to run very very little toe.
Fenders
A roll is just fine it will work ive done it on 195 45s just fine. A slight pull will make everything easier but is not necessary. Ill sat it again YOU DO NOT NEED TO PULL YOU FENDERS with the correct amount of camber, tires and ride height it works fine
come cavolo è possibile far stare dentro al passaruota un 8j et0 senza allargare niente? che camber esagerato va messo??
Ho pesato i Rota RB 15x8 ET30 con una bilancia pesapersone con il metodo pilistation+cerchio e poi solo pilistation come tara...
Bene....
7,1 kg
mazza che rocce
pilistation Ha scritto:Ho pesato i Rota RB 15x8 ET30 con una bilancia pesapersone con il metodo pilistation+cerchio e poi solo pilistation come tara...
Bene....
7,1 kg
..cioè circa sette etti a pollice in più sul cerchio da 15
www.luxspeed.eu
..quello che non c'é non si rompe e non pesa..
Pesati i Work.. 5.9kg hu
313x Ha scritto:hehe, CJ non è che ti confondi... :chessygrin:
gli ineffabili te37 di coopersimo sono questi qui
[Immagine: 350trug.jpg]
Scusate se riesumo, che misure sono?
NA 1.8 '94 elan style
Lorenzo
[LoD]Gandalf;254992 Ha scritto:come cavolo è possibile far stare dentro al passaruota un 8j et0 senza allargare niente? che camber esagerato va messo??
non ho ancora provato i cerchi di ilcoyote sulla mia ma penso che il mio camber basti, non lo so con precisione perchè è stata abbassata dopo l'ultimo allinemento, comunque con -3°30'/-4° e al massimo una rollatina fatta meglio con le 195/50 ci stanno. ora mi passa il dito tra gomma e parafango (in diagonale) il + del lavoro è da fare davanti sull'attacco del paraurti.
Feature: Spaghetti-Garage
dmax23 Ha scritto:Scusate se riesumo, che misure sono?
15X7 ET? boh forse intorno ai 40
Nicola
Gilda
Vai...guardarteli per bene :giggle:
http://www.mx5italia.com/showthread.php?...ronzo-15x7
Nicola
Gilda
Wink [NB/NB FL] Cerchi 14 OEM della NA su NB/NBFL paoloc 8 4,617 04-04-2024, 17:20
  [Vari] Nuovo decreto per omologazione ruote Roberto Mella 1 2,176 12-07-2022, 16:39
  [NA] Consigli lubrificazione cuscinetti ruote Vittorio "Speedster" 6 6,807 29-04-2020, 17:40
  [NC/RC] Scatto alle ruote anteriori Falex88 9 8,180 07-02-2020, 17:41
  [ND] bulloni ruote mx5 nd 0nicola0 0 2,907 26-06-2019, 20:15
  [NA/NB]  Per tutti quelli che hanno ribassato l'assetto della propria mx5 crissss 82 63,197 27-05-2019, 09:36
  [NA] (Lamento) Il decreto ruote è una ca*ata pazzesca! AleHachiRoku 42 38,720 08-12-2018, 20:48
  [Vari] Curiosità riguardo alle ruote MelvinUdall 4 5,566 09-04-2018, 18:41
  [ND] Coppia di serraggio dadi ruote e martinetto gluca 12 14,887 22-10-2017, 17:34
  [NB] miata nb con ruote nuove salvatore pepe 2 3,909 11-09-2017, 11:06
