I.L. Short shifter kit
Scusate , io avevo visto quello Cobalt sul sito di Moss http://www.moss-europe.co.uk/Shop/ViewPr...dexID=4830
Non sarà quello del Ilmotorsport , ma questo costa meno di 70€.
KTM lc8 Adv
Maledetti alitatori di scimmie ;-)
- NC 2.0
-midified engine by Lazzeri
-camme mondiale R
-volano oem alleggerito
-AEM intake
-collettori 4-1 scat I.L.
-terminale cobalt
-re-map ECU Mondiale R
-engine torque damper
-corner balancing
-sway bars rx8 gialle
-end links regolabili I.L.
-full powerflex
-wilwood 4 pot calipper
-awr brake dukt
-nankang ar1 235/40/17
-wedssport tc105x 17x9
-rev.limiter gauges
-carbonmiata rear splitter
-MX-5passion io c'ero!!!
SOTTO 5000 NON è AMORE!!!
È già. A sta cifra diventa un interessante esperimento.
KTM lc8 Adv
Eek interessante!!!
dez Ha scritto:Scusate , io avevo visto quello Cobalt sul sito di Moss http://www.moss-europe.co.uk/Shop/ViewPr...dexID=4830
Sembra lo stesso che vende GW:
http://www.good-win-racing.com/Mazda-Per...-0091.html
Citazione:[h=2]Customer Reviews: Short Shifter--For 6 SPEED TRANS ONLY! 2006-2013 6 Speed[/h] I purchased the Short throw shifter for my '08 6sp GT roughly 2 months ago. I'm incredibly satisfied with the feel of the shifter over the OEM shifter. Shifts are very notably reduced in length and overall the shift pattern has become stiff, notchy, and very direct. This could be considered both a negative or a positive depending on the driver, as it can be considered "difficult" to get into gear, particularly first and second gear, especially when the transmission is cold. This can easily be rectified using ford motorcraft transmission lubricant. I enjoy the feel and will not be reverting to stock.
The stock reverse lockout mechanism is fully retained, however, the spring that is included with this shifter is weak. It's not nearly as stiff as the OEM spring, and as a result, with a weighted shift knob (such as the voodo knob) the shifter will rattle and vibrate as the spring allows for an excess amount of vertical movement.
Furthermore, the stock shifter is rather bulky in diameter, while this shifter is much thinner. This unfortunately makes it impossible to retain OEM sound dampening as the original foam rings provided are much too large. You'll notice a very large increase in gear whine, road noise, and transmission heat.
I feel that removal of these problems should be considered heavily in future updates of shifter design, as the constant rattle, gear whine, and heat from my shifter can be an annoyance at times.
Overall, it's just worth the price with its current issues, and being the only STS on the market for the 6spd NC, I'll be keeping mine installed for now.
-- Alan H., San Diego, CA ( 2008 MX5 GT )
InZomma.... : Blink :
Outback H6 Combat Wagon
  [NA] Short shift molto duro imgruth 7 2,679 09-06-2024, 15:57
  [ND] Confronto Short Shifter per Mazda ND CravenSpeed vs. IL Motorsport LupoTHP 12 10,673 10-06-2021, 12:57
  Short Shifter? [Slide] 73 41,206 29-05-2021, 07:29
  [NA/NB]  short shifter il moro 3 3,342 11-11-2019, 18:18
  short shifter antonio gaggiano 17 8,202 01-06-2012, 17:56
  Short shifter per NC pure_driver 8 4,735 16-01-2011, 13:24
