  • 1 voto(i) - 5 media
[NC] A proprosito dell'attivazione del Cruise Control nei modelli 2006 ...
#71
bill_viper Ha scritto:I think I've got a mountain in front of me after reading your post...damn..
In order to test the presence of the software in the ECU, I created a chip device with a couple of resistors & switches (3 euro for all).
[ATTACH=CONFIG]29095[/ATTACH]
Zef, what if you tell us what resistor(s) to use to emulate the cruise control buttons?
This way we could proceed by testing the presence of the software.
bill_viper, not all hope is lost. ECU software is just, software... and can be replaced. For instance with the EcuTek ProECU kit, which flashes a new image to the ECU's firmware.
I *guess* ( but I am not sure about it 100% ) that the new image is of the whole software. In that case, the Cruise Control features will be embedded in the new ECU software image ( they are required to take advantage of the full RaceRom features ).
Since a reflash of the ECU is always a good thing ( the OEM maps are just a stereotype and they don't reflect the individual characteristics of your actual engine, even if you haven't done any modification to it ), and will yield better mileage, performance and reliability for your engine, based on what you put your priorities on.
Just my two cents.
Switch condition Resistance (ohm)
ON OFF button pressed Continuity
CANCEL button pressed 117—123
SET/- button pressed 666—694
RES/+ button pressed 2,156—2,244
No button pressed No continuity
mauro Ha scritto:Grazie ancora per il tuo aiuto, adesso non mi resta che smontare e cercare .......Thumbup
Ecco fatto trovato il fatidico cavo segnale velocita e il Pilot cruise control funziona benissimo....!!Big GrinThumbup
MX5 NC LE:
[video=youtube;fu42S6S1ngs]https://www.youtube.com/watch?v=fu42S6S1ngs[/video]
Thumbup
zef Ha scritto:[video=youtube;fu42S6S1ngs]https://www.youtube.com/watch?v=fu42S6S1ngs[/video]
Thumbup
:buahah::buahah::buahah::buahah::buahah:: Thanks ::clap2::primo::whistling:
MX5 NC LE:
Raga la mia è stata costruita nel novembre 2007, secondo voi ha ancora il software sulla centralina per il cruise control?
Ciao,
non riesco a ritrovare i pin in centralina perchè la numerazione sui miei connettori è diversa cioè conettore A con numeri da A1 a A60 e connettore B con numeri da B1 a B60 mi puoi dire riga e verticale guardando il connettore da dietro oppure se hai lo schema della numerazione che hai usato tu?
Grazie
Ciao, ho acquistato un volante con gli switch per il cruise e vorrei cimentarmi nell'installazione del cruise sulla mia rc 2.0 immatricolata gennaio 2007 quindi immagino produzione 2006 ..
purtroppo nn riesco a trovare uno schema dei pin della centralina.. per caso sapete dove trovarlo o se sono già segnati direttamente su di essa ? Mi sapreste dire la misura dei capocorda da recuperare o dove comprarli?
Ultima cosa, ho letto su un forum straniero che era possibile saldare il led smd sul quadro strumenti per la spia di attivazione del cruise e questa funzionava ma a quanto ho capito loro avevano già tutto cablato e gli bastava montare i tasti per avere il cruise funzionante .. forse era versione USA, ora non ricordo .. sapete se su quella europea basta saldaere il led ?
  [NC] Montare cruise control Lorenzo749 21 15,055 26-01-2022, 15:55
  per collegare lo sbrinatore dell'hard top... Gas Guzzler 67 58,716 08-11-2021, 18:53
  [NC] Cruise control after market User 8965 2 3,371 02-09-2020, 21:02
Lightbulb [NA/NB]  Voltmetro al posto dell'indicatore olio stock tHeo 13 9,364 10-07-2020, 16:25
  [NB FL] Attivazione 3a chiave lcaremi 0 2,632 25-03-2019, 22:10
  [NC] Sistema manuale di attivazione ventola radiatore mauro 18 15,600 13-06-2017, 10:24
  Cruise control albirrozz 2 3,668 02-10-2015, 08:42
  cruise control Husky1992 64 41,935 10-09-2015, 07:32
  Installare il cruise control su NA shinnolo 29 22,721 09-09-2015, 06:58
  Sostituzione altoparlante porta laterale destra NC del 2006 gidisa 1 2,992 11-05-2014, 22:02
