[NA] Info Torsen
#61
x-vas Ha scritto:non ne ho idea, ma ormai dubito che il tuo a lamelle sia ancora prestazionale.....
...e comunque dovresti cambiare anche i semiassi e conica : zip :
ma l'ho trovata a roma, dubito fosse di provenienze estera.
dalle misure dei freni mi sembra un 1.6.. ma devo tornarci per fare qualche foto.
quindi devo sperare che sia un 1.8 : Neutral :
Yess!
Vale la regola del 1800!
No!
Il VLSD optional sulla 115 non mi risulta essere revisionabile..quando si chiede ad un meccanico se è capace di revisionare un differenziale a slittamento limitato, ti dirà sempre di si (apri, cambi i dischi, chiudi).. il fatto è che il differenziale in questione ha un funzionamento particolare:"A VLSD is made up of thin perforated plates that are suspended in a silicone fluid. The plates shear the fluid as the wheels rotate at different speeds. This shearing can equalize the different wheel rates thus limiting slippage. The VLSD only provides a 15-20% locking function when new, so they are not really meant to be a performance item. I have found that the locking action of the VLSD takes a moment to activate when one wheel starts to slip so it usually takes affect after you have already exited the corner. They are really meant to help you get the car moving from a dead stop in slippery conditions and not a performance aid. The VLSD works just fine for it's intended street usage but it will effectively stop limiting slip, from a performance point of view, at some point as the plates can break, the silicone fluid can leak and the tolerance between the plates can wear. For more detail information on how a VLSD operates check out the links page for the BMW and 4x4 articles.[FONT=Arial]The shop manual states to test a VLSD you put a torque wrench on the hub (wheel in the air) and turn 90 degrees with 11 ft lbs of torque (car in gear). This should take no less than 4 seconds. If less then you have either an open diff or the VLSD is toast. Another test for a good VLSD is to jack up the rear with both rear wheels in the air. A good VLSD will turn both rear wheels in the same direction when manually turning the drive shaft. The open unit (or toasted VLSD) will turn the wheels in the opposite directions. There is no rebuild kit for the VLSD and the unit is completely sealed so you can't even get inside it short of cutting it"..[/FONT]
Dalla citazione si capisce anche che il VLSD delle 115 è abbastanza una ciofeca..
..dal mio punto di vista, se si cerca un prodotto "stradale", il torsen è ottimo; per fare drifting, un LSD cazzuto è migliore ma su strada risulta un po' esagerato..
Articolo molto interessante, grazie Smile
Ex Mazda Miata - 1991
Mazda MX-5 1.8 - 1994
Mazda Miata M Edition - 1996
o questo
http://carbonetic.wordpress.com/carbon-lsd/ :chessygrin:
Pdor figlio di Kmer Ha scritto:c'è anche la possibilità di revisionare il vLSD cmq...anche se non sò quanto costi (non credo poco)
mi sto informando in merito a questo... appena so qualcosa lo scrivo qui...
tra l'altro in fase di revisione si potrebbe anche far cambiare la percentuale di bloccaggio.
leggendo i vari commenti di chi ha il torsen pare che il povero lamellare faccia pena in confronto, ma ci sono un sacco di auto sportive e da corsa che montano i lamellari (probabilmente con percentuali di bloccaggio diverse)...
ho visto che i prezzi di un lamellare costruito da zero partono da 1200 euro circa, ma in caso di sostituzione lamelle e forse ingranaggi (ma non so se sono necessari) il prezzo dovrebbe essere sostenibile...
Bisso Ha scritto:ci sono un sacco di auto sportive e da corsa che montano i lamellari
quali auto?
dipende pure Quali lamellari...
siete OT!
ah, no è domani il giorno della polemica.....
NA 90 CV Montego Blu
Vendo ricambi/accessori
  [ND] Torsen 1.5L Lorenzo Ciuffa 4 1,443 10-06-2025, 12:09
  [NA/NB]  Paraolio pignone Torsen Alessandro 36 14,885 11-07-2023, 15:43
  [Vari] Valori tarature autobloccanti Oem VLSD-Torsen T1-T2-NC-ND Kublai 8 4,644 16-02-2023, 21:24
  [NB/NB FL] info differenziale gradient 2 2,455 09-12-2021, 14:47
  [NB FL] differenziale torsen mazdaspeed 182 103,287 18-11-2021, 16:05
  [NA/NB]  Revisione Torsen a Milano Pb81 1 1,769 09-10-2021, 17:42
  [NA/NB]  Torsen vs Retromarcia pierpower 3 2,646 25-05-2021, 09:34
  [NB FL] Olio differenziale torsen em98 2 4,164 22-04-2021, 09:36
  [NA] Mi date una mano per l'acquisto di un torsen? lsky 24 12,285 15-03-2021, 13:13
  [NB FL] Info cambio 5 marce falcon89 11 7,037 24-10-2020, 11:33
